Satellite Maps
To make a map chart, first select latitudes and longitudes and choose the Map chart type. Then change the map tiles to satellite imagery by going to the chart format tab and checking the "Satellite" checkbox in "Map Tile Settings":
Now the points or heatmap will be rendered on top of satellite imagery of the location:
Thank you! Your submission has been received!
Oops! Something went wrong while submitting the form
