Using SQL Formatters
👤 This section is intended for SQL Users.
Ensure the date and time columns are in the right time zone using simple formatters:
select [my_timestamp_column:pst] from my_table
select [my_timestamp_column:date] from my_table
Periscope can compose multiple formatters at once, e.g.:
select [my_timestamp_column:pst:date] from my_table
This query will select gameplays by PST date over time:
The "Query" button above the chart will display the expanded SQL Periscope generated:
Periscope supports many different kinds of formatters, including the following:
